Kaapelitehdas Helsinki 16.-17.2.
http://www.kustomkultureshow.com/index.html" onclick="window.open(this.href);return false;
Paikalla mm. Ollin 2CV-rod!
"Citroen 2CV could be real hot rod!
Olli Erkkilä´s fenderles, channeled and chopped rod is imaginative project mixing old ragtop Citroen to early 50's Hot Rods.
2cv production started in 1949. Color, interior and many other details have been made that the vehicle could be build from one of those of the first 2cvs. Olli wanted to use much Citroen parts as possible, so car is running with original 2cv front wheel drive technic. Car has been under construction now 1,5 years. It's not completely ready, there's still many small things to do before spring! "
The Kustom Kulture Show
Re: The Kustom Kulture Show
...ja hei: jos ei tämän illan bileisiin ehdi mukaan, on näyttely auki vielä huomennakin, vinkvink
Kaksipyöräisten kiiltoakin oli niin, että silmiin sattui.
