(Auto)polttimoiden valoteho
cxtb2
Viesti Kirjoittaja cxtb2 »
On useampaankin kertaan ihmetelty polttimoiden valotehoa, varsinkin erilaisten uudempien tekniikoiden eroa vanhempiin, joten keräsin Osramin sivuilta ilmoitettuja valotehoja yleisimmille polttimotyypeille.
NIGHT BREAKER PLUS 64150NBP (H1)
Nominal wattage 55 W, Nominal voltage 12 V, Light technical data Color temperature 3500 K
Luminous flux 1550 lm
Lifespan Lifespan B3 150 h, Lifespan Tc 300 h
Additional product data Base (standard designation) P14.5s
Certificates & standards ECE category H1
NIGHT BREAKER PLUS 64151NBP (H3)
Luminous flux 1450 lm
Additional product data Base (standard designation) PK22s
Certificates & standards ECE category H3
NIGHT BREAKER PLUS 64193NBP (H4)
Nominal wattage 60/55 W, Nominal voltage 12 V, Light technical data Color temperature 3600 K
Luminous flux 1650 / 1000 lm
Lifespan B3 80 / 260 h , Lifespan Tc 160 / 400 h
Additional product data Base (standard designation) P43t
Certificates & standards ECE category H4
Lamps with metal bases for cars 3796 (BA9s, 2W.)
Nominal wattage 2 W, Nominal voltage 12 V
Luminous flux 12.5 lm
Lifespan B3 300 h, Lifespan Tc 750 h
Additional product data Base (standard designation) BA9s
Lamps with metal bases for cars 5007-02B (R5W, 5W.)
Nominal wattage 5 W, Nominal voltage 12 V
Luminous flux 50 lm
Lifespan Lifespan B3 350 h, Lifespan Tc 800 h
Additional product data Base (standard designation) BA15s
Certificates & standards ECE category R5W
Lamps with metal bases for cars 5008 (R10W, 10W.)
Nominal wattage 10 W, Nominal voltage 12 V
Luminous flux 125 lm
Certificates & standards ECE category R10W
Lamps with metal bases for cars 7506 (P21W )
Nominal wattage 21 W, Nominal voltage 12 V
Luminous flux 460 lm
Lifespan B3 250 h, Lifespan Tc 500 h
Certificates & standards ECE category P21W
Lamps with metal bases for cars 7528 (P21/5W )
Power input 25 / 6 W, Nominal wattage 21 W, Nominal voltage 12 V
Luminous flux 440 / 35 lm
Lifespan B3 180 / 1250 h , Lifespan Tc 290 / 4000 h
Additional product data Base (standard designation) BAY15d
Certificates & standards ECE category P21/5W
Lamps with glass wedge bases for cars 2721 (T5, 1,2W.)
Nominal wattage 1.2 W, Nominal voltage 12 V
Luminous flux 7.5 lm
Lifespan B3 500 h, Lifespan Tc 2000 h
Additional product data Base (standard designation) W2x4.6d
Lamps with glass wedge bases for cars 2820 (T10, 2W)
Luminous flux 13.5 lm
Lifespan B3 600 h, Lifespan Tc 4000 h
Base (standard designation) W2.1x9.5d
Lamps with glass wedge bases for cars 2825 (W5W)
Luminous flux 50 lm
Lifespan B3 350 h, Lifespan Tc 1000 h
Additional product data Base (standard designation) W2.1x9.5d
Certificates & standards ECE category W5W
Re: (Auto)polttimoiden valoteho
Viesti Kirjoittaja laakeri »
cxtb2 kirjoitti:On useampaankin kertaan ihmetelty polttimoiden valotehoa, varsinkin erilaisten uudempien tekniikoiden eroa vanhempiin, joten keräsin Osramin sivuilta ilmoitettuja valotehoja yleisimmille polttimotyypeille.
Ja mielenkiintoisesti voi varmistua tuolta siitä, mitä silmä väitti:
SILVERSTAR 2.0 64150SV2 (H1)
Nominal wattage 55 W, Nominal voltage 12 V, Light technical data Color temperature 3400 K
Ja ihmetellä tuota, mikä ei tunnu pitävän paikkaansa:
LifespanLifespan B3 250 h, Lifespan Tc 450 h
Vai onko tuo 2.0 aivan uusi? Päätin nimittäin hommata syksyllä Xantian lähivaloihin Silverstarien tilalle Night Breakerit. Yllätyin hieman, kun valoa ei miun mielestä tuntunut olevan juuri enempää, mutta ovathan ne paljon pidempi-ikäisiä kuitenkin kuin Silverstarit.
cxtb2
Osram on kyllä päivittänyt polttimoitaan kestävämpiin, samoin muutamavuosi sitten philipsin nightvisionissa oli erä huonosti kestäviä, ja tuntuu, että kestävämpi polttimo hehkuu viileämpänä ja antaa vähemmän valoa, olihan noille kestolle ja valoteholle annettu toleranssitkin, minkä sisällä valotehoa "saa" heitellä, yleisesti saaattaa olla 15%.
zX-files
Viesti Kirjoittaja zX-files »
Tavanomaista Longlife-polttimoa voi pitää valoteholtaan miinus 30% versiona kun käytetään samaa asteikkoa kuin noissa plussaversioissa.
cxtb2
itseäni kiinnosti tuo "normi"polttimoiden valoteho, kun totesin, että XM:n peruutusvaloilla ei kertakaikkiaan näe mitään, vaikka siellä on P21W, eli josta pitäisi periaatteessa lähteä senverran valoa, että parimetriä auton taakse näkisi, varsinkin kun niitä on 2kpl siellä.
tuollehan luvataan 450lm, joten hankin kokeiluun 9W. LED polttimon joka on toteutettu yhdellä LED-elementillä, ja linssillä suunnataan kaikkimahdollinen valo sopivaksi valokeilaksi, valotehoksi luvataan 800lm.
ja kyllähän tällä LED-versiolla jo näkeekin paremmin, hehkupolttimolla kun piti peräyttää lähinnä jarruvalojen punaisessa loisteessa, nyt näkee jo eriväriset kohteettekin takana, ja kauempaakin kuin 2m. päässä. ja peruutusvalojen aktivoitumisenn erottaa päivänvalossakin.
zX-files
XMn pakkivalossa vika onkin siinä valaisimessa, jo se lasin "punainen häivytys" rastereineen vie tehoa, ja heijastinkin on jotain ihan muuta kuin hyvä. Taisi olla se kuuluisa sokea pärekorin tekijä suunnittelemassa XM valot :oops:
XM-Hannu
Viesti Kirjoittaja XM-Hannu »
Onko kenelläkään kokemuksia motonetin myymästä valonvahvistin-sarjasta, joka kai hakkuritekniikan avulla nostaa valoille menevän jännitteen lähelle 15 V. Auton oma valosyöttö jää vain ohjausjännitteeksi, valojen sähkösyöttö tehoboxille otetaan suoraan akusta, toki syöttöjohdossa olevan sulakkeen läpi. Valoteho kasvanee lähes 40-100% :roll: , mutta mainos lupaa myös polttimoille pidempää ikää :roll: . Voiko pitää paikkaansa? :?:
svc
Viesti Kirjoittaja svc »
XM-Hannu kirjoitti:Onko kenelläkään kokemuksia motonetin myymästä valonvahvistin-sarjasta, joka kai hakkuritekniikan avulla nostaa valoille menevän jännitteen lähelle 15 V. Auton oma valosyöttö jää vain ohjausjännitteeksi, valojen sähkösyöttö tehoboxille otetaan suoraan akusta, toki syöttöjohdossa olevan sulakkeen läpi. Valoteho kasvanee lähes 40-100% :roll: , mutta mainos lupaa myös polttimoille pidempää ikää :roll: . Voiko pitää paikkaansa? :?:
http://www.motonet.fi/phpBB/viewtopic.php?f=46&t=12322&sid=89280a7496cd174a699af975991f2636
