http://www.halfwaterhalfgas.com" onclick="window.open(this.href);return false;Fortune 500 petroleum companies are trying to keep this from you: Water is a POWERFUL fuel but...you need the RIGHT match to light it!
This actually works better and safer than gasoline and diesel. But what would happen to them if you knew the truth? They'd lose billions!
This can all change and you can start saving 60% on gas overnight. We will show you how to do it the right way, step by step.
Jotain aivan muuta.....
Citroën BX 19 GTi 16V 1992
Re: Jotain aivan muuta.....
Ja sit jos vielä laittaa sen magneettijutun polttoaineputkeen, ja sen pyörrerotohärvelin ilmanottoon, niin voi alkaa jakelemaan bensaa tankista, kun se lisääntyy sielläThis can all change and you can start saving 60% on gas overnight. We will show you how to do it the right way, step by step.
Näin on.....
