Päivän harmin aihe
Re: Päivän harmin aihe
Ja paha pettymys..Kun jo toinen tilaamani paketti Rockauto.com :ista ei sisältänyt sitä jääkaappimagneettia,joka aina aikaisemmin on ollut paketin pohjalla..Herää epäilys että liittyy "Unioniimme"....
Vai olisiko taustalla Magneettimedia?
Taustalla lienee ihan tylsästi IATAn säännöt magneettisten tavaroiden ilmakuljetuksista. Mahdollista, mutta työlästä+kallista, ainakin ilmaisten kaupanpäällisten kanssa..
In Order for Magnets to be Shipped by Air
For air shipment purposes, magnets are considered "dangerous goods". As such, the International Air Transport Association's (IATA) Dangerous Goods Regulations (DGR) must be followed.
Flux measurements of all packages containing magnets must measure less than 0.00525 gauss 15’ from the package. If flux measurements are less than 0.002 gauss when measured 7’ from the package, the package is not considered to contain magnetic material, and hence is not classified as Dangerous Goods. However, unless the package is extremely secure and there is no chance that the contents will shift or that shielding will be damaged in transit, it is safer to proceed as though the package falls under the DGR.
Packages containing magnetic materials must be clearly identified according to Packing Instructions 902. This calls for a "Magnetized Material" label to be affixed, and for a Shipper's Declaration of Dangerous Goods to be provided to the carrier.
Personnel responsible for shipping magnets by air are required by the Federal Aviation Authority (FAA) to be trained for that purpose and for those training records to be maintained. Contact your carrier for more information and guidelines.
Note that, in addition to transportation costs, Dangerous Goods fees apply to each package shipped by air, oftenmaking shipping magnets by air quite costly.
No,ilmeisesti IATA:n kontrolli petti,sillä Jeepin ylätukivarsien etuhelojen mukana sitten tuli magneetti.
Sitruunaseppä
Ilmalaivoissa on moninkertaiset suuntimavälineet ja lentäjän kännykässä pari appia lisää. Kun mä olin pienempi, olin poistamassa magneettisuutta valtamerilaivassa, kun hitsauskaapelit oli magnetoineet paikkoja. Kompassi näytti Turkuun, kun piti nimenomaan välttää tuo kaupunkien kaupunki.
Kaikki tiet vievät Turkuun, jo vanhat roomalaiset tiesivät sen...Sitruunaseppä kirjoitti:Ilmalaivoissa on moninkertaiset suuntimavälineet ja lentäjän kännykässä pari appia lisää. Kun mä olin pienempi, olin poistamassa magneettisuutta valtamerilaivassa, kun hitsauskaapelit oli magnetoineet paikkoja. Kompassi näytti Turkuun, kun piti nimenomaan välttää tuo kaupunkien kaupunki.
Nähdä Naantali ja kuolla, oli kai se toinen heidän viisautensa.
Invapaikalle ajavat kirjakansan edustajat
,siis suorastaan vit...aa.Itsellä lupa ja kun nuo liikkumiseen tarkoitetut raajat oikein vihoittelee,ni eikö perkele joku ko.ryhmän edustaja ole ajanut paikalle.Mahtaakohan bannit iskeä facessa jos alkaisi laittaa kuvia autoista
Iso mies ja pienet sitruunat.
Sanotaan nyt, että itseä ainakin Vee-tuttaa oli kuka tahansa joka ei jaksa kävellä jos se onnistuu.jotunen kirjoitti:Invapaikalle ajavat kirjakansan edustajat,siis suorastaan vit...aa.Itsellä lupa ja kun nuo liikkumiseen tarkoitetut raajat oikein vihoittelee,ni eikö perkele joku ko.ryhmän edustaja ole ajanut paikalle.Mahtaakohan bannit iskeä facessa jos alkaisi laittaa kuvia autoista
Kerran yritin ehdottaa paikallislehdelle et olis tehnyt jutun näistä turhaan invapaikalle parkkeeraajista. Vissiin liian pieni city kun ei ole uskallusta riittänyt.
Esimerkiksi jo 80-luvulla Karpon ohjelmasta (aikamoinen aasin silta, kuka muistaa jakson) tullut Heinoska omistaa kyseisen ruudun vieressä pankkiautomaatin jonka käyttäjät ajaa säännöllisesti invapaikalle. Oikein pysähtymällä viereiseen ruutuun tulisi matkaa lisää .....
https://www.youtube.com/watch?v=l9qnAIXpGLU" onclick="window.open(this.href);return false;
Itse olen miettinyt että leikkaisi mustasta jeesusteipistä pienet hameen muotoiset palat ja liimaisin ne invapaikan kyltteihin sen pyörätuolin päälle. Hyvässä lykyssä siitä tulisi nettimeemi ja somekohu joille salaa hihitellä ja vielä paremmalla tuurilla syntyisi keskustelua tärkeästä asiasta. Sukulaisilla on invatunnus ja ihan tarpeellinen, heillä jokainen ilman tukea kävelty metri näyttää olevan tuskaa.jotunen kirjoitti:Invapaikalle ajavat kirjakansan edustajat,siis suorastaan vit...aa.Itsellä lupa ja kun nuo liikkumiseen tarkoitetut raajat oikein vihoittelee,ni eikö perkele joku ko.ryhmän edustaja ole ajanut paikalle.Mahtaakohan bannit iskeä facessa jos alkaisi laittaa kuvia autoista
- citrophoros
Kuuluisin henkilö, jonka selän takana olen odottanut vuoroani Otto-automaatille, on kuollut.
Waldemar Wallenius.
Waldemar Wallenius.
25 C5 X PureTech 225
21 C4 PureTech 130
19 C3 Aircross 110
15 C4 Aircross 1,6i
12 C4 VTi 120 Exclusive
05 C4 1,6i 16v VTR coupé
03 C5 2,0i 16v SX berline
98 Xsara 2,0i VTS coupé
95 ZX 1,9i Volcane berline
93 BX GTI berline
91 Visa 14 TRS berline
Myös HSL:n busseissa on vatsakkaille miehille varattuja paikkoja. Symboli on sama, mutta ilman grilliä.Aakku kirjoitti:
Perussuomalaiset näköjään luopuvat pakollisen ruotsinopetuksen vastustamisesta. Ymmärrän kyllä että politiikassa pitää tehdä kompromisseja että pääsee pöytiin jossa päätökset tehdään, mutta siinä käy helposti niin ettei enää ole periaatteita joita puolustaa eikä kohta enää kannattajiakaan. Luulisi että nykyisillä kannatusluvuilla olisi varaa olla vähän jyrkempikin.
Ehkä ne ovat tulleet persukarvan verran järkiinsä, jota tosin uskallan eppäilläSäxä77 kirjoitti:Perussuomalaiset näköjään luopuvat pakollisen ruotsinopetuksen vastustamisesta. Ymmärrän kyllä että politiikassa pitää tehdä kompromisseja että pääsee pöytiin jossa päätökset tehdään, mutta siinä käy helposti niin ettei enää ole periaatteita joita puolustaa eikä kohta enää kannattajiakaan. Luulisi että nykyisillä kannatusluvuilla olisi varaa olla vähän jyrkempikin.
Se on pakko olla pakkoruotsia kun Ahvenanmaalaiset ei osaa suomeajptcool kirjoitti:Ehkä ne ovat tulleet persukarvan verran järkiinsä, jota tosin uskallan eppäilläSäxä77 kirjoitti:Perussuomalaiset näköjään luopuvat pakollisen ruotsinopetuksen vastustamisesta. Ymmärrän kyllä että politiikassa pitää tehdä kompromisseja että pääsee pöytiin jossa päätökset tehdään, mutta siinä käy helposti niin ettei enää ole periaatteita joita puolustaa eikä kohta enää kannattajiakaan. Luulisi että nykyisillä kannatusluvuilla olisi varaa olla vähän jyrkempikin.
Käsittämätön vuosisataisten sortovuosien mukana tullut muinaisjäänne jota kukaan ei kumminkaan viitsi pakollakaan opetella, mäkin kysyin kerran meidän pakkoruotsilla kidutetulta että tules kääntämään mulle vähän Bloketin autoilmoitusta, katseli vähän ja tuumasi ettei ymmärrä tuosta yhtään mitään
Kunniajäsen
Vähintään 3kk ajokielto
tuliko kiintiö täyteen?ilkkata kirjoitti:Vähintään 3kk ajokielto
AivoinfarktiRalle kirjoitti:tuliko kiintiö täyteen?ilkkata kirjoitti:Vähintään 3kk ajokielto
Ai hitto. Niin se taitaa olla vakio juttu noissa "pää" tapauksissa.ilkkata kirjoitti:AivoinfarktiRalle kirjoitti:tuliko kiintiö täyteen?ilkkata kirjoitti:Vähintään 3kk ajokielto
Kaveri tais kanssa saada samamoisen vuosia sitten ja kortista lähti muut kuin b, ammattilupa lähtikin sitten 5 vuodeksi.
Paranemisia ja toivotaan pikaista kortin paluuta.
Naapuri sai taannoin vuoden ajokieltoa, lääkäri väitti että on epilepsia vaikka itse väitti kivenkovaan, ettei siitä ollut kyse.Ralle kirjoitti: Ai hitto. Niin se taitaa olla vakio juttu noissa "pää" tapauksissa.![]()
Vuoden päästä kun alkoi kysellä ajolupaa takaisin, selvisi ettei mitään ajokieltoa ollut ollutkaan.
Taisi lekuri alkaa itsekin epäillä diagnoosiaan, mutta ei kehdannut myöntää sitä potilaalle...
Oman harmin aiheena sain eilen opetuksen siitä, että öljyntäyttökorkki kannattaa laittaa kiinni heti eikä 800km ajon jälkeen. Tommonen bokseri ruiskii sitä aika kivasti joka paikkaan kun nokkaketju kulkee täyttöreiän alta...
Eilen Lidlistä ostamani "Stinger" kanankoivet kirvelivät mennen tullen...
Jos on Subarusta kyse,niin pidentää auton elinkaarta huomattavasti..Teuski kirjoitti:Naapuri sai taannoin vuoden ajokieltoa, lääkäri väitti että on epilepsia vaikka itse väitti kivenkovaan, ettei siitä ollut kyse.Ralle kirjoitti: Ai hitto. Niin se taitaa olla vakio juttu noissa "pää" tapauksissa.![]()
Tarkentavana kysymyksenä: kirvelivätkö ne kahdesti samassa osassa kehoa? Poistuivat siis samaa tietä kuin tulivat sisään?Northstar kirjoitti:Eilen Lidlistä ostamani "Stinger" kanankoivet kirvelivät mennen tullen...
Eturengas tyhjeni Porvoossa eilen illalla. Siis ajossa, ensin ihmettelin että onko sähköinen ohjaustehostin jotenkin rikkoutumassa, kunnes oireet selvenivät kolmen km:n ajon jälkeen. Lelumetallivanteen sisäkehällä (?) painuma, josta ilma puolessa vuorokaudessa pihalle? Putosin sisäkaarteessa asfaltin reunalta, kantatiellä. Eikä edes maalipinnassa naarmua…
