Xantia II - follow me lights
Lähetetty: 03.01.2015 14:07
Kirjoittaja longgo
Hi
In most of the new cars, there are build in Follow me type lights, and as many things in Xantia that are out of the list.
My first "hack" was to add relays to Low / High Beam Lights and to take the amperes out of the stalk switch in the cabin. What i have done was first to remove the original 10A fuses (A1-A2, B1-B2)
On A1/B1 pin are the relay controls, from relays out via 10A fuses goes to A2/B2.
Later on(few months), it come the circuit for "follow me", based on NE555 timer and variable resistor.With the second one you can change the delay based on: T(sec) = 1.1xR(ohms)xC(farads) or in my case:
T(sec) = 1.1 x 80 000Ohms x 0.00047Farads = 41.36sec
Maybe the circuit is far from perfect but do the job. Feel free to test,modify and use.Good luck
Re: Xantia II - follow me lights
Lähetetty: 04.01.2015 00:37
Kirjoittaja Akaile
Did you take any before-after pics about the lights in the dark? Xantia light wires are joke and I would do the same relay adding if I wouldn't use xenons.
Lähetetty: 04.01.2015 02:51
Kirjoittaja longgo
Sorry, i didn`t. After adding relays, also i replaced all bulbs(high / low beam) with H1 Osram Night Breaker+ and can say there is improvement. With Xenon will be one idea better but it will move it to illegal state for driving in Finland and also the lamp glass itself has ribs what destroy the beam of the xenon light.Of course that is personal choice, but i consider if that was crystal look kind of glass as on the new models it will be times better and nicer to add xenon.
One important thing is: as +12V supply line, can be used one small bolt point what is situated in plastic cover in front of the small sized fuses.Also need to be checked the connection under that same box. I mean the whole small fuses box under, has few plugs that link the fuses to the cable lines. That pins get oxide, or that small moist related chemical cover and loose also contact strength which also make the things bad.
Lähetetty: 04.01.2015 21:05
Kirjoittaja Akaile
Yep, the illegal issue has been brought up into my eyes multiple times in this forum... However, Xantia lights are not the worst with xenons in matter of teasing other drivers. I have adjusted my own ones a bit lower than normal lights and nobody hasn´t ever blinked lights for me. Still with this adjustment the lights are better than originals.
But anyway, good work with those relays and it definitely is not a bad adding for any Xantia.
Lähetetty: 05.01.2015 18:27
Kirjoittaja longgo
I have witnessed how the police stop mate who was with passat B5 with Xenon lights and told him to remove them when he come home
Actually there are Chinese crystal front lights for Xantia II and probably with them and xenon bulbs will be much better but.. since in the past i have bad experience with DEPO main beam lamps.. somehow do not with to give around 300e just to find is shit or in Katsustus some nice dude to write down - non original, to be removed
And that is my last version. At least for now work fine, but lets see what will be when the weather get hot(if get hot
Lähetetty: 12.05.2015 21:53
Kirjoittaja longgo
In the fun of statistics.. On evening after rain I found my lights on.. Somehow there was 1.8V jumping trough the power transistor and was keeping the relays On. So that was end of "no problem state".
Day after I manage to find small relay (about 300Ohms coil) and figure out that if NE555 can drive up to 200mA that will solve my problems. And here it is:
All that work this time proved well
Lähetetty: 13.05.2015 17:18
Kirjoittaja Sitruunaseppä
Be prepared for a blackout or a car fire. How to prepare oneself, I wouldn't know. Just jealous.
